lost my power steering while adrift ??? hows that happen
ok so this is the deal i was in a parking lot ( yes it was closed and i was entitled to be in it, and dont condone going into random parking lots)... so back to the issue
i had setup a gymkhana course and was doing some filming.. i was doing a drift at moderate revs and had the steering wheel almost at lock and did some slides and what not next thing i know i have no power steering at all.. when im stopped and try to turn its hard as shit than if i rev it a bit it makes a wild noise kinda like a belt whine and steering starts to move a bit... a little easier but not much when actually driving it feels kinda normal at speed
so not sure what that is and not sure what to check
any help would be much appreciated thanks
also ill search on here for similair
most pumps do not like big rpm, while being held on lock
Often cause fluid boil or seal failure
hopefully you just boiled the fluid and you can just top it up and leave it idling to bleed up
Good luck
