Defin Controller/Solder help
AdamOst
So I was wondering why my boost gauge wasnt working, thought maybe it was on the wrong vacuum line. Checked the power going into it and it seemed ok, till i pulled the case apart for the contorller and saw this. Second pin on the left should be there for ground.
Fixable? maybe manually solder the wires to the board? THe others are pretty loose too. If so it would be easier than having to pull everything out to get a refund form the seller.
If so is there anyone around the shore/auckland whos pro enough to do it for me.
mine did that . i just flogged 2 pins from an un needed plug on the board . with a pointy soldering iron its surprisingly easy . even without a soilder sucker or wick . just get it hot then give the whole thing a flick and more than enough soldier will fly off and you can remove pins . prolly want to get them off something else broken you have lying round
or yeah just wires straight to board and put a seperate plug in it
