Subaru Leone RX II
Stodart
nice 1 both :) so is that full transmission set up a standard feature on all RXs?
maybe dreaming too much to get a rally spec one like this ie re pic. ( the STI of the the RX maybe?) :-\
Leone 3rd generation RX Group A rally specs sedan and coupe from wikipedia subaru leone
Activity: (1985–1989)
Power @ rpm: 190 bhp (142 kW; 193 PS) at 6500
Torque @ rpm: 230 N·m (170 lb·ft) at 5200
Length Width Height: 4370 mm 1660 mm 1425 mm
Weight (kg/BPM Ratio): 1060 (0)
Transmission: 4x4 Fulltime
Engine Type: H4 Boxer SOHC x 2
Engine Position: Boxer Turbocharged
Engine Capacity: 1781 cc
Engine Bore: 92 mm (3.6 in)
Engine Stroke: 67 mm (2.6 in)
Engine Compression: 7.6:1
Engine Valves: 8
Engine Carburation: Electronic Multi-Point
Turbo: IHI
Body Doors: 2 (Coupe) or 4 (Sedan)
Body Type: Coupe and Sedan
Brakes: Ventilated disks
Fuel Tank: 60 L (16 US gal; 13 imp gal)
http://www.cardomain.com/ride/3122951/1987-subaru-rx
Cheers will keep looking. maybe talk to rally people etc for rear spoiler? the spoiler and bonnet scoop for intercooler certainly help the cars looks.
try these guys, otherwise Auz/US/ebay etc maybe? http://www.subspare.co.nz/index.php
from wikipedia:
The Subaru EA-82 engine was produced from 1985 to 1994. It came with a carburetor, single point fuel injection, or multi port fuel injection. Most of the technical advancements introduced to the EA82 were utilized in the Subaru EJ engine, specifically, the SOHC valvetrain, and multi-point fuel injection.
Specifications
Subaru EA-82 Engine
Displacement: 1781 cc
Bore: 92 mm
Stroke: 67 mm
Compression Ratio: 8.7:1 or 9.0:1 SPFI According to Subaru Factory Service manuals: 9.0:1 "carb" 9.5:1 SPFI
Valvetrain: SOHC
Horsepower:
Carb - 84 bhp (63 kW; 85 PS) at 5,200 rpm
SPFI - 90 bhp (67 kW; 91 PS) at 5,600 rpm
MPFI - 97 bhp (72 kW; 98 PS) at 5,200 rpm
Torque:
Carb - 101 lb·ft (137 N·m) at 3,200 rpm
SPFI - 101 lb·ft (137 N·m) at 3,200 rpm
MPFI - 103 lb·ft (140 N·m) at 3,200 rpm
Found on
1985-1994 Subaru Leone
1985-1991 Subaru XT
EA-82T
The EA-82T engine was introduced in 1985 for the GL-10 models, and later on RX Coupe models. It is a turbocharged version of the MPFI EA-82 with modified cylinder heads and lower compression pistons.
Additional specifications
Turbo: IHI model RHB5 VF7
Compression Ratio: 7.7:1
Supercharging Pressure: 7 psi
Horsepower:
1985-1986: 111 bhp (83 kW; 113 PS) at 5,200 rpm
1987-1990: 115 bhp (86 kW; 117 PS) at 5,200 rpm
Torque: 134 lb·ft (182 N·m) at 2,800 rpm
http://www.7tune.com/1986-subaru-leone-rxii-turbo-coupe/
All of that information is for the US versions :)
would not take anything from wikipedia as gospel
but the EA82t ratings sound about right
I would never put a bonnet scoop on the RX BUT i intend to fit an intercooler ( RS WAIC one)
I have a fully forged rally spec engine in my shed,( it has aftermarket cams as well as it has a real lumpy idle) I intend to fit this to my RX in the next few months, with the WAIC and an XT spider intake, also thinking of fitting a VF8 as I have a few lying around.
will see how well it goes after that, may have to send the gearbox away to be repaired as it has an issue going into 3rd
 We are borg said:
yeah could be true
the rally engine was taken out of a car running 15psi and never missed a beat so may have had some remedy work done :)
as I have 2 spare engines it is worth a punt :)
yea plenty of ppl have rallied them but i suspect theyd have adjustable computers and associated mods aye.. what i read was prolly more about playing around at home with turbos and boost and not doing associated mods then they go bang sort of thing
 gazzy2000 said:
i read that the EA82T\'s are p1ss weak and dont like having bigger turbos fitted or adjusting the boost.. something to do with heat in the drivers side head
Read also and a heard from someone else that there were limitations with Ea 82s head design ie single exhaust port heads (flow limitations) for extracting power from being turbocharged
