Check engine codes simple DIY fix or not?
GeeCasia
Check engine light lit up and its showing 12, 21, 32, 33..
12 Starter switch or circuit
21 Coolant temperature or circuit
32 Oxygen sensor or circuit
33 Vehicle Speed Sensor or circuit
just want to know if theyre a easy DIY fix, or should i take it into a shop cheers.
if it driving ok? at least two of those use the same power feed, i\'d start by replacing the ECT sensor as its the cheapest then reset the codes and see how it goes.
does the car drive ok? or is it maybe using more gas than normal?
what model car?
thermo sensor issue - its in memory !
Fan will run continuously if this code is logged as a fail safe, and ecu assumes engine temp @60 deg, which often causes hard start when cold too
Thermostat will be fine - unless you have overheat issues or trouble getting engine up to operating temp
replace sensor -reset ecu -
But it sits between 3/4 and 1/2 right?
primarily just above halfish? that\'s where mine sat, but had no anti freeze/anti-boil in it yet.(2 years of inactivity lol)
if that operating temp worries you, I\'d suggest(if you haven\'t already) a coolant flush, and check your oil and it\'s levels. anti-freeze anti-boil helps keep everything at a medium temp, so effectively car runs cooler. (if i\'m wrong here please correct me, I\'m in no way an expert just operating under my understanding)
