2001 e tune- not smooth when cold
ANTZB4
 Andy_Mac said:
just found this on the subaru site, they say not to use ethanol on any jap imports and basically not on any nz new turbo models as the ethanol eats stuff you don\'t want it to..
Ethanol suitability for Subarus
Most Subarus purchased new in New Zealand since 1990 are capable of running on the ethanol blended fuel now being introduced to the local market.
However any Japanese domestic specification models which have been imported here second hand (i.e.). second hand Japanese imports - should not be run on the ethanol blended fuel.
These cars are only suitable for 3 percent blended fuels. The fuel being sold in New Zealand has a 10 percent ethanol blend.
The 10 percent ethanol blended fuel could cause damage to the fuel line, fuel injector sealing, fuel pump or fuel regulator of these second hand Japanese imports. The fumes from the blended fuel after combustion can also have a harmful effect on the catalytic converter, the exhaust gas regulator and the muffler.
Those Subarus which can use the 10 percent ethanol blended fuel have a 17 digit VIN number beginning with either JF1 or JF2. The VIN number can be found at the bottom of the central door pillar on the passenger’s side of the car or in the engine bay.
The second hand Japanese imports which should not use the ethanol blended fuel have VIN numbers starting with 7A8.
A small number of models sold new in New Zealand cannot use the 10 percent blended fuel. They are.-
Legacy RS, Legacy GT, Legacy GTB, Legacy RSK and Legacy Blitzen from 1990 onwards; the Impreza STI from 1997 onwards and the Forester STI. They do not have JF1 or JF2 VIN numbers.
Owners who are not sure if they can use the ethanol-blended fuel in their car should consult their nearest Subaru Authorised Dealer.
About 3 years on it almost exclusively for me now, V5 WRX stock fuel setup, no issues. V5 WRX was on the no no list but I was using it for 6 months before I saw the list lol.
Just Subaru covering there backsides I think, understandable.
 Timmah']
[quote name='B4_685 said:
Hey guys - Have a 2001 RSK B4 - same issue with cold start in the morning - Until coolant temp gets to around 60 degrees, it stumbles when you accelerate. Only recently been getting an intermittent CEL so going to change knock sensor - anyone had any issues pulling off the intercooler? The two turbo setup seems to have a s#*%load of hoses/connections going everywhere!
Will see if new knock sensor doesnt fix it, next will be coolant sensor...
I\'d suggest you go into Stubaru and ask if he can pull any codes for you before you start replacing things randomly. Only happening when cold does suggest temp sensor though.
Thanks mate - emailed Stu - he reckons could be the sensor and will check the code for me next week
Intercooler off isn\'t a big job - there\'s only 3 or 4 hoses involved, just need a loooooong flathead screwdriver and 20 mins or so
Getting it back on is more annoying than removing it, cheap ass plastic turbo-->cooler hoses don\'t have much (any) flex in them, use the opportunity to replace with silicon while it\'s all apart
Thanks Marky. Thankfully Japanese owner replaced all hoses with silicone ones before I bought it. Cheers for the insight :)
