HOLSET fittings
DRFVDR
Nothing to do with the RX, I am turboing one of our buses I did the exact same model a few years ago using a Garret, The model has been discontinued and the Holset is the closest i could get, only issue being that the outputs( both exhaust and intake ) use a "v" clamp set up the intake may not be an issue as I can machine the outlet to suit and weld an extension on if needed, the exhaust will need to be "v" clamped so will chase one up, I should be able to get something from cummins as their engines use Holset exclusively
