BOV question.....
Hailz
Hi, am trying to track down a funny whistle sound comming from my engine bay, also revs under idle drop at times, have had AFM rebuilt ect, I\'m leaning towards th BOV leaking.
Now I\'ve removed the BOV and it might sound like a dopey question but are you meant to be able to blow a bit of air through the inlet to it when its off the car or are they meant to be 100% airtight, I\'d imagine if I can do this that the seal is getting worn and I could imagine a couple psi leaking past it under load as the whistle sound only comes in under light boost.
1997 gtb legacy
Any help would be great
 funkytown said:
turn the bov round backwards and see if it makes the noise. (seriously).
factory ones an go backwards, but usually you get \'george\' sounds, not a whistle.
Ok this "George" sound can you elaborate on this lol, the sound I\'m getting is kind of a funny whistley groan it\'s pretty strange, what will flipping the valve around do?
Cheers!! :)
Hey Funkytown, Thanks for advice about plumbing the BOV in backwards. It got rid of "GEORGE" sound :D (my George was a Harmonic note akin to someone blowing across the top of a coke bottle).
My question is, can I keep it plumbed backward or do I have to buy another Blow Off Valve? Does it have any adverse effects ie. damage, increase fuel consumption, decrease in power?
Thanks.
