Water pressure problems
johnny5
So I have been having a cooling system problem that has just appeared.
The car is letting out water into the overflow tank while it is not much its still worrying, then when it cools it kinda sucks it back in it hasnt started spitting out of the overflow tank but am pretty baffled as to why. The car is not overheating but I can faintly smell coolant so maybe there is a leak?
At first I suspected the head gasket but Im not blowing white smoke, no signs of water in the oil I did however take the radiator cap off and run the car while I didnt notice bubbbling the water did expand pretty fast.
The radiator cap appears to look ok but there is a white stain round the rim where the cap goes on.
While my first thought is to buy a new radiator cap what else can I do to check my head gasket is good and solve the rest of my problems before I take the car in to do a pressure test on the system
could be an air lock.. whereby components in the engine where the air is get real hot and when cool water does actually flow past it it boils instantly.. which is especially true when u remove the cap as this can make water flow properly into/past the airlock and as it does the water instantly boils blows it out the cap. makes u think its H/gasket.
So bleed system properly first i.e. jack front of car as high as poss etc
