2000 legacy gearbox ratio
pl0x
lmao i did the thing which i hate to see people do... not give all the info lmao DAH
um its a manual non-turbo sedan (BE5?)
really i wanna know if it can be fixed, or does it need a new gearbox
should be 3.900. Piece of cake to bolt a new gearbox onto a non turbo. If the price is right id say do it
hmm crap... there are no turbo gearboxs that are 3.9?
i was thinking about a rwd wrx gearbox? would i need to go to a 4.111 diff aswell?
prolly better as i doubt a n/a could break a wrx box and diff?
Or you can just swap the rear diff too. Only takes an extra $100 and an hour and youll have a slightly faster awd n/a
i c... but if having a 4.111 gearbox then a 3.9 diff, this will make the gears seem longer/shorter wouldnt it?
im wanting a clutch/box/diff comb which will be overkill for a n/a rwd car, so it can take all the thrashing i could deliver
i was thinking a rwd wrx box & maybe a new clutch (sti or wrx) for now, when/if the diff breaks go to a wrx diff?
yea well thats the other thing, it's not going to take much more to do it all at the same time and get it over and done with
Even with a turbo box, your just going to snap axles or wear out synchros or break engine mounts. Fitting a turbo box is by no means a ticket to trouble free thrashing.
Mhm i doubt il get to that extent, im not going to go doing burnouts etc, or drop clutches on dry roads etc, just want it for some fun times on private wet/gravel roads etc
