Brake pedal requiring double pump
Hi All,
Ok, so before the last track day, fitted new pads, new fluid, etc, and brakes were working fine.
For some reason, recently, I have to pump them once before they'll grab properly like in their former glory.
Today we re-bled all the brakes, filled with MBF600, and still, the same problem.
They're Subaru 4 pots on the front, 1 pot's on the back.
Please note, this is a recent thing.
I am planning on going in the winter series this Sunday, but I can't really drive it like it is.
Thanks for your help.
it could be a bit of pad knock off. or maybe the master cylinder is bypassing. with the car off does the pedal creep to the floor?
Hmm, nope the pedal doesn't creep to the floor. And, ha ha, imagine that. 200km/hr, handbrake on.
It could be the piston sticking, not sure how to check for that.
A smart man said it could also be a wheel bearing, which could've knocked the pads out.
pull your caliper off one at a time and SLOWLY push the pedal down and watch the pistons come out evenly... if not id start by rebuilding the calipers esp if your racing...
2 main causes of this are
1, play in hub causing pad knock off
2, pads wearing unevenly (tapered) this causes excessive piston push back as the pad tries square up to rotor when pedal released
Hence why when you pump the brakes all is good
  • 3 weeks later...
Clamp off all 4 brake lines (with proper brake line clamps so you don't damage the hose!!) and release one at a time pumping the pedal in between. When the pedal drops away, you found which one/s is causing the problem. Just gotta find the cause after that.
 caspros said:
Is there an easy way to test for this play in hub ? (<---novice)
Take off the wheel and try and wobble it ???
i got this in my car atm just wondering weather the play in the hub could be caused by wheel bearing???
or is there any other things that cause it
