Bc5 2pot rear conversion help needed
kwikfix
 Drunkenmonkey said:
do bc5 axles fit into your hubs?
No they do not. :\'( Outer cv is peculiar to the hub. So you need the correct axle to fit it. Then the inner cv wont fit the diff.
However the inner cage and balls can be swapped out and changed to suit the outer cone on the bc5 inside cv. :)
