Installed a catless DP, now have a CEL???
polyarkos
Hi guys and gals,
I\'ve just installed a Subtech 2.5" downpipe/front pipe on my BP5. Driving up to Hanmer I got a CEL but the car is running the same as before.
I\'ve replaced the 02 sensor as it was very very black. CEL went away for 15min but is now back.
I\'ve looked for the black and green connectors but cannot find them under the drivers dash.
How can I check and clear the CEL?
under the glove box area there should be another set of plug (not sure of color) should be beside the green ones. connect it and turn ignition to on and than off after few seconds. disconnect and recheck again. that should clear the codes.
i have always used subaru select monitor so havent actually done this. this is what is written in the service manual so m just reading and relaying it to you.
dont think you can actually pull out code though because the engine code normally start with P on these newer models i.e P0031, P0036 etc etc.
UPDATE: Checked CEL and came up with P0031 and P0037 (Thanks Scottiescottiescottie).
Since I have replaced the 02 sensor we cleared P0031 code, but still left with P0037
Upon further inspection I have also blown the SBF-5 fuse which will throw the above codes.
I\'ll replace the fuse in the morning and see if this clears the codes.
  • 3 months later...
Did you find any frayed/damaged wiring on the old O2 sensor? Short Circuit will blow the fuse from what I can gather.
