wastegate springs
hi there guys. ive recently bought a tial mvr wastegate its come with no spring in it but the springs have been supplied.
i want to run 10psi wastegate pressure so ive found the spring guide.
now my question is where it says " black, red". do i combine those colour springs or does it mean i can use either of those for the neccessary pressure
cheers guys all help much appreciated
Uhh nope - a spring is a spring - ask anyone who\'s used one of these gates - they allways boost 0.2-0.3 more than they are rated too
Only on the vee band gates this is - the 2 bolt gates actually boost what they\'re rated too but springs are different dimensions
The spring will allways find the equilibrium point where pressure over comes the spring rate
Meaning it will allways boost what the spring is - mounting it in different spots won\'t change the boost pressure - it can have effects such as boost spike and boost creep however if flow isn\'t enough
Hey vadster - somewhere I have a spring that does 0.7 on its own and one that does 0.5 on its own - u can have em of u want
