96 v2 wrx coolant leak w/ pic
ebg5 NZ
its fucked bro . its called " the header tank getting its period "
the tank is FRP fiber reinforced plastic . the radiator end tanks are the same .
it lasts so long then eventually it is brittle and leaks / snaps .
soultion find an alloy tank on trademe if your lucky . or mod a steel one of a v3 to fit . and replace the rad with n alloy one next time you are bored have 300 spare
cheers g-unit
I replaced that tank with the one I found at pick-a-part and topped up the coolant with ~800ml demineralised water, after taking it for a spirited drive I pulled over and checked the tank, no new spillage.
Now I need to remove the crap that has already spilt
Thanks for the help
