Correct hose clamps for radiator hoses
johnny5
 lachlan said:
they will probably smash a plastic rad outlet if your not carefull
how are they hard to put on . just point the bolt head to somewhere you have access ?
not much room down there on a v7 point the bolt where you can get to but the thread comes out the other side and has to go somwhere so not much options for it really which is why Im asking if there is something better to use and yup if tightened enough it will break the plastic outlet which I am aware of but ya gotta be dumb to fo that
Is the worm type of clip you tighten with a screwdriver alright to use will it hold the pressure
 JoKer said:
overkill a tad
these are fine in most applications
just what I had lying around when i got my raiator top tank redone.......
so these will be fine to use! Thanks joker was just wondering if they will be able to hold the pressure what are these called I thought worm type but could be wrong
