external wastegate
victorjf
got a friend who bought a sti v7 with external wastegate, however car didnt have boost gauge, today we put a boost gauge on it, and went for drive....car is boosting over 20 psi, so, we r thinking to put a MBC on it and set it up to 15 psi, however i would like to known if would work, or if we got change the wastegate spring first. Thanks
Victor
 victorjf said:
wastegate is street spec branch , but i dont know whot to identify if is Tial or not. Anyone know how to identify if is tial or not ? the one hes got is exctaly this one http://www.listselltrade.co.nz/item_itemid_50197.html
cheers
Victor
it\'s a knock off replica of a tial wastegate, still does the job. I\'d say it\'s running the correct spring.
If cars been tuned to run at 20psi peak, a mbc set @ 15psi will do the job, but you will prob find will make the car run a bit poo rather than running as if the boost has just been turned down,..
 Disruptz']
[quote name='victorjf said:
wastegate is street spec branch , but i dont know whot to identify if is Tial or not. Anyone know how to identify if is tial or not ? the one hes got is exctaly this one url]http://www.listselltrade.co.nz/item_itemid_50197.html[/url]
cheers
Victor
its going over 20 psi, boost gauge goes till 20 psi, however when we r on full boost, it goes way more than 20, i would say 23 psi at least, so, if he buy a spring for 15 psi for tial wastegate should be fine ay ?
 loner']
[quote name='Marky said:
Sorry to state the obvious but an MBC cant make boost go lower - unless the factory solenoid is being used along with the external gate?
i think you are very confused dude.
Been waiting for someone to say that. How is it plummed up? If you have no mbc/ebc it should have one line running from comp cover to the wastegate. WOT will tell you what psi spring you have.
 loner']
wut
if it has a 20psi spring in it then it wont go lower with an mbc
only alternative is it has say 10psi spring and is using factory boost control - which is making it go more
whos confused
