Auto Trans Slip
titian
1991 turbo Auto Trans.
This old gearbox has done 320,000Km and its just started to slip (flare) in 3rd and 4th. :(
Is that it? New box time? Or can it be adjusted to cope with the wear?
No codes emitted from trans ECU ???
 DacerX said:
i had one that did that and got a new box for 50 bucks, done
LOL. I actually have a spare. Just wanting to maximise the current ones life. :D But im guessing its at an end.. Not an area of machinery that i know much about,:- these "Auto" things.
  • 2 months later...
As it concerns an automatic and its the "same" vehicle
This gearbox has virtually no reverse gear?. :\'( Does anyone have an answer or is it remove and replace gearbox time? It drives well in all four forward gears.
No codes have come up when you do the check. ;)
Help? :\'(
What do you mean by virtually no reverse? as in it engages and just flares really badly or it doesn\'t engage at all?
I would try getting the trans power flushed 1st with a wynns transmission flush machine, if that doesn\'t fix it, new box time... again haha
reverse flare is the issue :( It does engage but there is no power at the wheels even by raising the rpm considerably
Since this post i have discussed with Auto trans repair man. He said the reverse clutch pack is worn out. Ya! Another gearbox to replace :) :)
Same TYPE/Model NOT the same vehicle.
