1995 twin turbo boost probs
keachie
ive got a 95 legacy with a vf20 & vf14 its got no low down boost :( and when u get to 5000 rpm it goes ok what could it be ?
my last legacy went much better than this one i have now and that was running a vf13 & vf14
can anyone help me please
Munted turbo is likely, but seriously until you get an actual diagnosis don\'t worry about it - could be something super simple like a leak... somehow? or a wastegate jammed open or fckknows what - absolute worst case a new primary is like a couple hundred tops
If it\'s defaulted to stock boost (7psi or so) for any reason (which they can do) they feel almost non turbo anyway
sounds like its in limp mode. seeing as its not throwing codes i would be leaning towards the afm being shot. if you have access to a multimeter you can test it with car on and see what voltage it is reading. im sure marky will know what voltage it should be reading at idle and WOT
ok i think i found the prob its the auto going into limp mode cause when u start it u get the power light flashing 16 times. but u go 1st 2nd 1st 2nd 3rd drive then start it the power light goes out right away. and car goes sweet as :) till next time lol is there any way to check code?.
The 16 flashes is a centre diff issue, most likely a failed solenoid, easiest to either locate a good known replacement auto or do a manual swap, You will have to pull the intercooler/downpipe to confirm turbo failure, i\'ve seen quite a few with the exhaust wheel sitting on top of the catalytic converter, What part of the county are you in?
