Gaskets and a few other things
jimme18
Hi there
Bad news, it looks like my new (old) v2 May need new gaskets, I don\'t know much about this and I want to find out about prices. where should I look? how much would a mechanic charge to replace a whole set?
Also, are the exedy clutch range any good, what about the Xtreme ones? I can find clutches for between 500-750. I worry as I burnt through one in my evo 7 years ago, however admittedly I was drag racing at meremere during this time ::)
Should I look at a fly wheel as well? or just get the standard one machined?
These days I am not drag racing at night wars, or hammering the car, so I wonder if an OEM replacement would just be better for clutch. Rather than getting a HD one.
I have decided if they need to pull engine out I might as well get new clutch as well plus, get some spark plugs rather than me doing it later.
 subirex']
where are you located? if in auckland, come and see me. can do a good deal on genuine gaskets and install.
Unfortunatly not, I am in Auckland
[quote name='jost said:
You can buy genuine overseas for less than trade here (up to 50% off) Check the link below, You would have to confirm correct part numbers, they ship internationally, are quick and really cheap
This lot is $300 delivered, not bad for a genuine full engine gasket set.
url=https://partsouq.com/en/search/search?q=10105AA560]https://partsouq.com/en/search/search?q=10105AA560[/url]
Thanks mate
 jost said:
Just make sure you get the correct kit, i think they are around $600 in NZ so worth saving $$$
I brought some inserts for the alloy lower arm balljoints for about $8 each, beats the hell out of the $55 here
What site you use?
 jost']
What site you use?
They ship DHL Tracked and insured and cheap.
I use the following site for part numbers:
http://opposedforces.com/
You would need to do a bit more research but i think this is the right one at the top
http://opposedforces.com/parts/impreza/en_g10/type_56/engine/engine_gasket_and_seal_kit/
https://partsouq.com/en/search/search?q=10105AA120
Legend
