Power steer pump issue
im having issues fitting my powersteer pump it keeps hitting on my throttle body is there a smaller powersteer pump i can use instead of my square TT one. when its bolted up the back of the powersteerpump it hits where the throttle cable goes through stoping the cable from opening up the throttlebody.. help.. :\'(
 lachlan said:
yeah dont do that . i have a na one here which is a round pot so might be good for that . they all iterchange pretty easy
is it smaller than the TT ones? just having an issue with the back of the powersteer pump hitting the throttle body stoping it from opening up.
the legacys have a remote setup that bolts on to wrx . everyone does it when they flip the manifold
or get a na one
i have one lyin on the floor that is the same as this
they all interchange from the pump as i swapped this one with a 94 gt alloy one
edit . i see you have fliped it . buy a remote reservior one from a legacy . im not sure what model but all the ps pumps are the same . well within era\'s
 tydon']
[quote name='evowrx said:
True cut and weld. Make a bracket? Coolant lines look a lot better on the bottom hidden out of view imo.
i dont wanrt to take manifold off again... lol so rules out cut and weld.
Weld it on car.
or get a na one
would be keen on a Na reservoir one but cant be sure it also wont hit
