a few months back QIK_KAS's 94? TT wagon developed a cel66 and i spend a few days pulling all the vac lines out and cleaning everything i could get to. i never experienced the issue and its been working fine until today
cel is on and engine will cut as soon as *any* boost is developed. engine is smooth off boost. the cutout is very abrupt and quite violent when in gear.
the engine will rev all the way to redline in neutral with very little throttle, as long as your not making any boost. wot at this point just kills the engine till the revs fall past 3k where it picks up and repeats. kinda like a speed cut. i assume its pulling the spark.
this must be a limp mode but its pretty difficult to drive. apparently turning off the car resets the cel and its fine until the problem re-occurs.
any ideas? im guessing maybe the differential pressure sensor or map sensor.. knock sensor is a possibility but you would expect a knock cel.
oh, apparently coasting downhill in gear is what triggers the cel and resulting limp mode.
weird. anyone struck this before? im going to have another look at it tomorrow night
last time someone asked about this someone else gave all the common causes of 66. its SOMETHING in the sequential system, i think a couple of the common failure points are primary trubo and blowoff valve, cant remember what else
Is there a leak in the vacuum system?
hmm yeah i'm sure i had good vac last time, i remember learning how the vac cylinder system worked, but then again it was working last time..
i'll have a crack tomorrow and see how i get on. cheers
Many years of experience :)
As for an ASK ICHI, No thanks - there are too many know it alls about here, just waiting for 1/4 of a chance to flame me for incorrect wording
It's so hard to diag cars over the www. This is where many heads are better than one - ( different ways of reading a post )
Hmm. Exactly that happened to my car 6 months or so ago. Turns out that the bullet connectors on the ZS controller/ECU harness were not 100% seated and shorting out.
Unless Kas has a ZS controller, it could be something electrical? either a short or perhaps moisture in around the ecu area.
Unlikely, but another angle nonetheless.
66 is effectively ecu loss of control over system ( it's vac operated for the majority of systems )
Any sensor ie pressure differential , exh change over solenoid etc etc will all log individual codes
Where as 66 is the entire system
Your ZS fault would have been alowing primary turbo pressure to be incorrect
Oh yup. Cheers.
Learnt that solder = win! :D
    574.7k
