Block Storage
Joker
resting on sump is bad
planning to pellet wrap and stuff newspaper in holes to keep majority of dust out, aware if it is to be of any use it will need rebuild
drain water proper? fill with CRC?
what is recommended for long tern storage - or should I crack it open and clean proper etc
apparently ATF fluid in sump (turn it over a few times) is a reasonably easy "cryogenic" solution
and before you ask - turbo/injectors/clutch and crank/cam sensors are all gone
Do what my brother in law does with his engine parts. Dump it up in the mountains then drive back 2 years later, wire brush the rust off and good to go. Have successfully stored a block and head using this method and they ran fine afterwards.....for a while
