98 Forester Question
tydon
Looking at getting a 98 Forester its auto low kms if i get it i want to manual convert it are they simple to convert .
As easy as doing a legacy etc.
Manual Dash Cluster.
Matching Gearbox and diff?
and driveshaft?
or would i need to find a manual wrecked forester and take everything from that?
Or could i just use a wrx gearbox and matching diff and reuse driveshaft?
help please :) and thanks
Pretty sure it will det its ass off. A member here had a J2 in a non sti V5 and ran into heaps of det. Being foz theres a good chance it will have even higher comp making it worse. A non sti ecu would likely be an upgrade and still run the same/maf/440cc yellows but still need to make sure its safe.
Manual conversion easy enough, same as any impreza (its basically the same car)
Ej205 will set its nuts off (audable to naked ear at idle) as the c/r is off. Wrx ecu can be a good upgrade, no need to change anything as the v5/6 foresters and imprezas use the same AFM and Injectors
