suggestions? (evo ecu)
Hikari
probably the driver pack for the idle control. yeah they do occasionally fail for no good reason
whats the number on the chip? i can potentially have a go at repair if you don\'t mind postage to-from dunedin
otherwise look for the same ecu at a wreckers or tardme
I found someone with a similar problem in their mitsi ecu as well. Turns out the number burnt on mine is the driver for the icv
IC105 is damaged.
\'IC105 is ISC coils B1 and B2\'
I\'ve searched around places for an ecu but the only one I found was at parts connection and quoted me 295+ gst
Don\'t think thats worth it at all..
a repair soounds awesome, could you let me know on your details so i can ship it out to you
IC105 is damaged.
what ecu is it?
 Hikari said:
Evo1 MD187701
Evo2 MD312468 This is the one I had in my car for some reason
Evo3 MD322364
Any of the three works on the evo 1~3\'s so if any one of those turn up i\'ll be very keen to purchase. Thanks
Difference in ecu for cam profile 1 vs 2/3 and slight comp change and turbine housing in 3 iirc. Could try talk the missus into letting you buy her gizzmo chipped evo job?
