weird idle issue
tydon
i didnt torque manifld just put it on really tight didnt get compression test either
cambelt untouched.
i put in the longblock out of my RSB which was running mint with no problems and changed the manifolds over
i should also add i have no foam in my podfilter either it was stuffed lol
cambelt untouched.
A TB Vac Leak would show as a Constant Low Vac. Needle stuck a -15-16ish. You have Good Idle Vac. It\'s just wobbly.
The Intake Manifold needs to be Torqued correctly or the Gasket will Leak.
- Over Tightening causes Leaks.
- Uneven Tightening on Bolts causes Leaks.
- Under Tightening of Bolts causes Leaks.
- Incorrect Tightening Order can cause Leaks.
25nm or 18.1ft/lbs. Use a very thin/even smear of Adhesive Gasket Silicone, on both Gasket Faces if your worried.
Spray Ethanol/Engine Starter Fluid around the Gaskets, Idle will rise.
If not then time for a Compression Test.
 tydon said:
lol i dont have a torque wrench and just bought new gaskets lol :( sigh
Bugger... :-\
Time to invest in some Gear. ;)
Spray some Ethanol looking for Leaks first. If you find one, pull the Mani back off. Very gently so the Gaskets are Re-useable.
Then smear a light, even skim of "Adhesive Silicone" on both Gasket Faces.
Then Reinstall.
Don\'t over tighten it. 18.1ft/lbs isn\'t really that much.
Get them all as even as you can.
Or borrow a Wrench?
