grey smoke at idle and under accleration and not holding any boost pressure
Trex
  • Replies 60
  • Created
  • Last Reply
Top Posters In This Topic
Popular Days
 Trex']
97 body ver 5 bottom and ver 3 head turbos vf22 with a red line 2.2 stroker kit with some other goodies
Nice. ;D
/quote]More info about this \'stroker kit\'?
+1
Changing the Turbo should be a piece of cake. Real Simple job your car. ;) Have a look through the For Sale Section for a replacement Turbo. Good chance for an Upgrade?
Cosworth 2.2 liter stroker kit
Cosworth Forged Pistons (92mm)
Cosworth Fully Counterweighted Crankshaft (79mm)
Cosworth Forged Connecting Rods
Cosworth Rod Bearings
Cosworth Main Bearings
Cosworth Piston Rings
I say write it off and gift me the engine.
I\'ve done a lot to get if fix but that the moment it just the turbo buy the sounds of what I\'m told for a wof it just needs a few small thing and rust and the CPU is from the standard sti
 Rosssub said:
VF22/P20 Housing? What\'s the CHRA Seat Diameter? 54mm?
If you want info I have a P20 I can measure tonight. CHRA seat is identical on VF22/23/24/28/29/34/36 with P18/20/25 maybe others but def not VF30/37 with their funny ones or VF35 with P16.
If turbos off just check in the inlet of turbine housing it will have the number.
Not hard to get 20psi out of a VF#anything circa 3.5k on 2.0 so idiotic engine choice for anything with more displacement. The turbine wheel is shit on IHI for making massive power it limits you to under 250wkw on a seriously good setup. Most make 230wkwish with maxed injectors around the 6k mark.
 Trex said:
i guess with the stoker i guess it limits its over all capabilities but i rather got thought a turbo that my block
I would bet if you bolted a decent turbo on it more matched to the engine it would make it more reliable and safe while making more power at lower boost/IAT/EGT/EGBP/stuff that matters. Also a tuneable ecu would be wise considering your engine is way out of wack for the stock sti ecu. May be safe but unless you bolt it to a dyno and check knock/afr you dont know for sure and wont be near max potential.
The power figures for the VF stuff on the internet are fairy tales. Ive run a VF28/22/23/36 all s/s all nice street turbos but not built for 400m stuff or big displacement. But any of those turbos should see you into a high 11 with mental driving.
400fwhp yes 450fwhp cant see it.
