Electric window won't go up
tydon
Ok so this problem is not Subaru related it\'s happening in my current work hack till I fix my broken turbo lol. I have a Nissan primera 1993 sr18de p10 manual my passenger electric window won\'t wind up it only goes down . All my other electric windows go down and up fine. I used a battery on the wires to the motor and the motor works fine goes up and down when hard wired. Maybe a faulty window switch ? Also checked that seems find though
Sent from my hunk of crap
Not sure how the nissan\'s are wired but with a Subaru it goes through both the drivers main switches and the switch on each door. The usual fix with them is to disassemble each switch and clean the contacts (watch out for springs and small ball bearings).
Might be something similar with the nissan setup?
I disassembled switch and looked at joints etc also carefully with a acre driver connected joints to bake switch work and the down works and can hear it click no noise when trying to go up
There one in the drivers side which I\'ve replaced already because the front drivers motor was poked the switch was stuck on up and burnt the motor out do replaced motor and fixed switch
