normal vacuum presure at idle
dvs-b4
it sat at -20 when i had it plumed to were the wast gate t was (instead of the wastegate) bt have extended the pipe and teed it off from there nd corection lol its -15 i cnt read lol it boosts fine nd is stedy at idle
Somewhere around -20, applies to all cars as far as i know (253 v8 commodore only had -8, found the leak and fixed it, went to -20)
My GT wagon sits on -20
Edit - inlet manifold, at idle when motor is warm.
iv taken my boost gauge off that line nd put on another nd reads fine nw it sits at -18 to -22 but creaps up to -12 when its jst started and its cold bt cmes right within a min nd boosts to 16psi i was suprised
Ah yea sweet. Im a bit suspicious of the boost gauge install in my car.. Ill be taking it out a replacing it with a smoked one so it blends in a bit more. Gauge only shows 10psi when on full boost on the secondary but still hauls a turbo sounds healthy/ no vac leaks so hoping its the gauge
u have a b4 right? where have you got the T intersection for the boost gauge?
yea -9 to-7 sounds about right thats what mine does if i put my foot to the floor i hit 16psi of boost prity quickly but by then im well over the speed limit ;)
Guest Eastwolf
Hmmm all this is making me wonder about my B4.
When I rev the primary turbo is gets around 1 bar (is that 14 pounds?).
Then if I am going downhill with engine braking, it goes negative.
With engine off, it returns to zero.
Normal?
sounds prity normal to me its what mine does so i wouldnt wory to much its normal to go to vacuum when engine brakeing becouse the throtle is closed im prity shore i could be rong and yea it should return to 0 when the car is off
my car reads -20 when at idle, but when parked up the top of mt Ruapehu and the engine turned off it reads -5 to -10 lol must be the air pressure.
