99 BE5 B4 lumpy idol
last night my check engine light came on, and the car started idoling like it had lumpy cams, has anyone experienced this before?
Its coz your car has Race cams!!!! :D :D Nah seriously.. you have a BOV fitted?
yeah have had one for ages, Greddy Type RS, i was playing around with it the other day though, softening and hardening it, maybe i made it too soft?
I seriously think that aftermarket BOVs vented to the atmosphere just cause trouble.
If you have you BOV too soft then its probably releasing too much air and the car is miscalculating the amount of air in the system.
 keltik said:
AFM code would be consistant with a badly adjusted valve
yup had this occur when i just put my BOV on without adjusting it. turned out that the stock setting was too soft, then when i put it harder the turbo would surge a little under low boost, in the end i just went back to stock and had no problems since
to adjust them properly get your car to normal operating temp and then adjust it from there, you should be able to get it to a point where the car is not searching at idle and releases the air under low boost (well that is what you are aiming for)
-NOTE- by adjusting it at normal operating temp you will still have the idle searching while the car is cold but under normal driving conditions you will be fine
ive had to aftermarket bov on for yonks now with no troubles. but i recently did soften it up a lot, so should i wait till the car is warm then adjust the bov to quite hard, reset ECU then see what happens?
how do i reset the ECU, i couldnt seem to find the post where it is if someone could link me please!
nah gotta wait until pay day :(
ooooor i might see if i can get one tomorrow, how much u reckon they will be? > $20 from repco?
Subaru ones rule. Seriously. Only $24 last time i bought one and they flow good and fit better than the ones from repco etc
The real one for my car i had to squeeze into the airbox and the lid fits real snug. The repco one just sorta flops in there
Can't beat the genuine subaru air filter seen some test on the internet that proved they were good. They showed that your chucking $$$ down the drain just to get a flashy named aftermarket filter with a free sticker.
