fuel pump wiring
BriteLites
hi all
rewiring my racecar at the moment, its running a link g3 and ive come to fuel pump wiring...
currently has a walbro intank and wanting to add a bosch 044 external and surge tank.
does anyone know the current draw of either of these pumps? googles not coming up with much. and also would you wire them separatley or run one wire from relay and splice in the liftpump feed?
Richard
I ran a wire from the original fuel relay, split that off as a control wire to two new relays, then ran a new, fused wire straight from the battery for each of the two new relays. Then ran one to the Walbro and one to the Bosch.
I've just run 1 cable from the battery via a 30A relay that feeds both the intank and the external fuel pumps, the relay is controlled from the factory fuel pump feed. I added a switch into the new feed from the battery also so i can crank the car to get oil pressure etc.
