Oil Changers?
Sub Zero
I havent used them personally but being a mechanic have seen many cars come through that they have stuffed up/ missed things on/ put the wrong filter on which has fallen off and then cooked the motor (twice). \
REMEMBER, they don't SERVICE your car, they just change the oil & filter. Other things like a fluids check, drive-belt and brake pad check, Underbody inspection, battery level check and test etc are not done. Your much better off going to a local garage and getting a proper service done, might cost a bit more but then you know a mechanic has cast an eye over it.
I have used them around the country for a number of oil changes on various cars with no issues. The above is very true its just a fluid change at a decent price, dont expect anymore (Although there is a couple of places that go the extra mile).
But if your in a hurry and know what your getting I reckon there ok.
I had them do the oil and filter on the Mistral because it is a 300k old Diesel and the entire engine is covered in about 5mm of thick black awfulness.
It was cheap, and they checked the quantity/quality of both the trans oil and the rear diff, plus the guy doing it spotted a screw in one of the tyres. Couldn't complain really.
