Radiator leak
SpeedySub
Hey
After a long trip I found coolant through the engine bay, but it didn't lose much out of the radiator (overflow tank was empty though) and didn't overheat on the gauge. Took it to the dealers and they replaced the radiator and the thermostat. It has been running fine and not overheating, but there still seems to be overflowing coolant out of the radiator cap. The overflow bottle is ok. I will take it back to the dealer but could this be a head gasket issue causing this, I wan to be armed with some decent info when talking to them as my warranty runs out at the end of the month and I have a family trip to Wanaka in 2 weeks. Im confused as why it would be leaking out to the radiator cap and not going into the overflow bottle. Also if the head gasket did go after warranty and I have taken it in for these issues can I still claim it under warranty as the problem wasn't fixed?
 Rosssub said:
How's the seal inside the radiator cap look?
Good question- Last time I looked it looked ok. Would they have put a new cap on when the new radiator went in? I think it looks like the same one to my untrained eye. Also there doesn't look to be the usual signs of a H/G, but I have read that thats not always the case.
 Joker said:
around drivers side headlight? split end tank on radiator would be my best guess from here
The first time it happened before I took it in it looked like it had explosive diarrhea in my engine bay. Now it just looks like it dribbles out form under the cap or around the area of the cap and just dribbles down onto the fan surround. I'm guessing at this point it might be the cap. Im just nervous theres an underlying H/G gasket issue. Can anyone advise if it was a H/G that it could still be covered if the warranty runs out?
  • 2 months later...
 irishmangonemad said:
Where did you get your radiator replaced, and how much...if you don't mind me asking?
I got my radiator replaced under warranty at Crowesport. Seeing as this thread has been brought up again I thought I might as well post and update, the dribble around the cap came from a leaking over flow tube, I sealed it up and now its sweet as, no more leaks and temp gauge stays right where it should.
