WRX power steering pump whine
My power steer pump has a bit of a whine after blasting thro a stack of corners and Im getting over it. If its whining is it likely beyond rebuildable and just replace it or what? V5 wrx standard pump.
 RAYDEO said:
the pump on my mrs GTB was whining, i replaced the o ring on the intake side hose and it went completely quiet...
worth a shot considering the o rings are cheap as...
Was it leaking and did you replace it with a dex 3 rated oring? Which side is intake? Picking yours is external reservoir.
Usually the top is the intake, and if its "leaking" its sucking in air at the same time as fluid, meaning its not sealing properly, and causing the whine.
11205589_10153010306008495_4115788298091
or maybe your fluid is just old and needs replacing/bleeding...
