I only have one key for my Leggy and every so often I have a key scare lol!
So how do I go about getting a replacement? Do the 2001 GTB keys have transponders or anything in them or is it just a key with a built in remote?
My alarm has taken over the keyless entry functionality so I just need a key for use in the ignition.
any hardware shop should be able to cut a key for it i think? unless theres something special like you mentioned
$5 trying getting a key cut and if it works your sweet?
if 2001 GTB is same as 1999 B4, and it should be, then just get a key cut. no transponder in the key. hopefully you have two remotes for the alarm.
2002 Legacy, just got another key cut for it a few months ago, cost me a few dorrar at the key cutters. My advice is to use the spare for a few weeks to wear it down...otherwise its a right cnut to get it to fit when you need to.
Agree, or depending on the condition of your only key, i just started using my spear key now and left my original at home as a spear, save wearing out the original one just in case i need to cut another one later on
It ok if u lose your key
Slim jim the door ,break the steering lock and hot wire the sucker 2 minutes max :)
hhehhheeh
oops
did i say that out loud
So, where should I go to get a spare for my 2003 (BP5) legacy?
The way to check if it is a transponder key is when you pull the key out of the ignition there will be a flashing key lamp on the dash. No lamp, no immobiliser, no transponder.
Guest Bjcnz
Isn't the best way to check whether it is a transponder key if it is a nz new car or import? I'm fairly certain all imports dont have transponders in them?
No, not the case at all. Just check for the light.
Guest Bjcnz
Oh, thats what wingers had told me when I had imported my car and checked it over with them, thought it sounded a bit strange
I love Wingers. They're really smart.
hhehhheeh
oops
Dude just set a PIN code for door handle, and use spare key you have hidden inside - no need for all that effort!
Guest Bjcnz
 JoKer']
hhehhheeh
oops
Is the door handle code only for factory standard immobilisers? Just wondering if my TSR has it, always wondered
broad statement - not 100% sure on Gen III models
ALL GT Legacy's (wagons especially) have it (BF/BC/BG/BH) BC = 89-93? GT's both wagons and Sedans
It is a little bit different in the first gen ones in that the key has to be in the ignition for the door to unlock(did not make alot of sense to me )
 DRFVDR']
Lift door handle up when it is locked
if it beeps then it is fitted
How do you find out the code?
mine does that but i have no idea what the code is...
Yup 92 GT.. mines got it
    574.7k
