Cambelt kits
sobanoodle
I am looking for a BH5 cambelt kit. Checked partsouq and a full kit will set me back around $550-600 landed, not much less than a $625 genuine kit from Subtech on TM. Any other options? Trusted aftermarket brands? Ideally I'd want to spend around $400 :o
Probably want to go for the water pump with cast impeller 21111AA026
impp_1103_12_o%2Bsubaru_ej_series%2Bwate
The water pump front, right is a cast impeller that flows more water apparently, whereas the rear, left stamped impeller which is the one in your list (part 21111AA065) allows for water to bypass the blades and does not flow as much water.
That is of course if you order genuine. no idea what aftermarket will provide.
Edited by A_J_T
