Legacy Reversing/fog lights and electric mirrors.
bnicholls
Hi there,
I have just bought a 2005 Legacy B-Sport 2.0L station wagon. There are a couple of issues that I have:
1) The wing mirrors aren't working using the control to the right of the steering wheel. I discussed this with the previous owner and he said that they had never worked for him, he had checked the fuse but couldn't work out the problem. The folding switch works fine (they would be on different fuses though?).
Are there any common faults that I might be able to have a look at before I take it in? Bear in mind that I have little skill when working with cars.
2) The two rear LED lights to the left and right of the Subaru logo, are they supposed to be identical? At the moment the left one comes up white when in reverse and the right one is red when turned on with the fog lights.
Any help would be greatly appreciated :)
Perfectly normal and as it was intended by Subaru.
Try remove the battery then get in behind that panel and make sure the connector is properly connected. And might as well check all fuses just in case. But other than that if your not confident testing wiring then maybe taking it to an auto sparky is the best bet
