found on http://homepages.ihug.co.nz/~ccgrant/legacyrsk.htm
The turbo's have also been redesigned to spin up faster at the lower end. The suspension has been changed in the rear, from the McPherson Strut to a strut/Multi-link layout. Side airbags are now optional. Not noted above, but worth mentioning, is the fact that the NA DOHC motors gain Subaru's Active Valve Control System, essentially Variable Valve Control as used by most other major Japanese makers. Peak horsepower goes down slightly, but peak torque rises to 170ft/lbs arriving at 2800rpm, much lower than before.
if so what models have it? manual auto?
s there such a thing as a 2.0r
yes its true BH/BE's a re RSK's 1998 +
ccgrant is an original member of CS and thats the Legacy carbible right there
Erm, yeah, you're about 10 years behind. AVCS (active valve control system, Subaru's version of VVT) appeared in the BE/BH Legacy. Variable valve lift came in with the BL/BP Legacy.
FWIW
Its quite old now and i haven't updated it in a long time. Yes its probably got errors.
Also i no long use that ISP so im surprised it hasn't been deleted !!! So it will probably dissapear soon !
 Drewpy said:
My 2002 Blitzen6 Auto has AVC
Nope. Only BP/BL got that motor. You DO however have a variable geometry intake.
    574.7k
