Inlet manifold gaskets / leaks
Marky
So I munched an inlet manifold gasket through generic incompetence the other day, pretty black and white, bought a new pair and put them in last night
Still has a minor leak, enough to stumble at idle and sound like a tea kettle on boost
The internet gives me 50/50 opinions on if I should use sealant or not (I haven't), I'm also a bit cagey on going too tight on bolting it down more than I have as I don't think the spec is for a hell of a lot of torque (13Nm?)
Thoughts, opinions?
Yeah, it's weird. Definitely leaking at the gasket, blocked off the throttle body and put a compressor down one of the vacuum fittings, sounded like a tea kettle. Will persevere
Gaskets are new from subaru, changes with how hot/long the motor runs (no leak when cold, progressively worse with time & temp). Kinda weird but I'll work it out
