G4+ fault codes/ground issues
Nope fuel pump relay is earth switched and ignition/avcs loom relay is 12v switched. Both relays share the same 12v bat feed. Its doing some weird ****. If i knew exactly which wires from loom needed to be used id start from scratch. Hopefully trailer it to a sparkie that knows his **** this week before i burn it.
So ive triple checked all wiring and wired in a ground i thought i didnt need. Issues as follows:
No 12v at idle solenoid positive.
Above avcs lockout with avcs active solenoid dc sits at 49% left and 30% right with cams at 0. Cams are definitely not at 0 from the sound of the engine.
Needs extra 6ms of fuel.
