2004 BL5 Legacy 3.0r ECU
wipash
Hey everyone,
I've got myself a Tactrix cable with the hopes of learning a bit about my car, and maybe getting an e-tune.
Unfortunately, as far as I can find nobody has made any definitions for the auto BL5 3.0r. RomRaider gives me an ECU ID of 2F0A367416, which turns up exactly zero google results.
Does anyone know anything about these ECUs?
Car's a 2004 BL5 3.0r Auto.
Cheers!
Edited by wipash
3.0r... Auto?
There are some defs popping up for the pre-facelift legacys in the romraider forums,but yeah you kinda need to know the ecuid before that will be of much advantage to you. Might be worth getting hold of an app called "btssm" and an otg cable, that,if nothing else, will give you the ecu id.
Do 2.0 tactrix cables work for using SSM kwi_fozze? Can't quite remember if it does or not.
Could always just download free ssm and see if it works. Or borrow someones vagcom cable for it.
Throttlehappy is his name on here. Quite hard to get hold of though. just have to be prepared to wait a while for a reply, or get hold of McDoof who seems to have more luck than most getting hold of him.
Haha I tried FreeSSM last night, but it doesn't work with Tactrix 2.0. They changed the way it's presented to the system after the 1.3 cable (it's not a standard com port anymore).
Alrighty, I'll see if either of them turn up here in the next few days, otherwise I'll give 'em a message.
Easy enough to do just by pulling the ecu rom with ecuflash and then downloading a free xml reader/writer and opening it in there. It'll be one of the first few lines in it. Normally starts with a A
Process for pulling a rom is well documented here if you don't know how to already.
http://www.romraider.com/Documentation/RomRaiderFAQ#toc15
Edited by Andy_Mac
