03 H6 3.0L motor tapping noise
the.circuitboy
Hello all :)
I have a Subaru Legacy 03 with a h6 3.0L 6 cylinder motor in the last week/ 2 weeks it has started to make a tapping sound on the left back end around the number 6 cylinder, only when its warm not from cold
( have had and heard the 4 cylinder making the tap of death but this is no a tappy as the no a poping )
So far ive changed and flushed oil and run magnatec 10w40 in it and have add a valve cleaner additive as to directions but no luck.
Im going to start on seeing if the spark plugs are loose?
Any others know or have had this problem? Any help would be much appreciated.
very simpler to this
If you need to know any more info let me know and ill get back to you with what you need asap thank you.
Edited by the.circuitboy
