Romraider logging speed
For those of you out there using Romraider for logging purposes with stock ECU's and Tactrix cables, or similar, what kind of logging speeds do you see? Have always found it a bit hard to get usefull data out of the logs as its so slow to take samples. 3rd gear is ok but not legal on public roads where 2nd redlines at round 100kph but the logging speed is seriously lacking. Can do a pull to redline and the last rpm sample will be at like 6.2k rather than at more like 7.5k
Mine tends to sit at around 8 samples/sec or like 0.12sec/sample.
Is this around what others get or is mine reading considerably slower than expected.
Can't really drop many more parameters out as then the logs only really usefull for virtual dyno
Plotting.
