Where to buy cambelt kits?
IZichard
My cam seals are starting to leak so I figured I may as well do the cambelt bits while I'm in there.
Where I can get good price on a genuine cambelt kit for a v7 wrx (ej205 with avcs)?
I was going to get parts from partsouq but they don't actually have the belt itself in stock anywhere... hmmm. Could get the idlers and tensioner from there though.
I don't need the waterpump, just belt + idlers + tensioner.
16 minutes ago, evowrx said:
Partsouq dude then buy belt locally.
That's kinda what I was thinking just wondering if there was a kit for convenience.
To clarify, am I correct in thinking I need.
13073*A     smooth idler
13072*B     smooth idler
13073*C     smooth idler (is this actually another idler?)
13085         toothed idler
13033        tensioner
cam seals (already have)
and belt which ill get locally.
I used this kit when I did mine, except mine was cheaper as the belt was Mitsuboshi instead of Subaru. Not sure what sort of markup they put on over Partsouq tho as I've never really looked.
If you decide to buy individually I have 4x genuine cam seals and 1x crank seal if you're interested.
EDIT: Never mind that I just read you don't want a water pump. Could always ask them to do a kit without though.
Did you mean to link to the kit?
Cheers for the offer but I already have the genuine cam seals and crank seal.
S***, here: http://www.trademe.co.nz/motors/car-parts-accessories/subaru/engines/auction-1162675349.htm
They mention there that they don't supply the "no. 3 idler", which you will need and mentioned in your OP.
13073*C (13073AA230).
14 minutes ago, IZichard said:
I probably just buy it from partsouq, it is only $25. Unless you are willing to sell it for almost nothing  since shipping and all.
Oh if buying thro partsouq just get it off them. Was meaning if you bought one off tm.
Yes the two big smooth idlers are identical.
