Issue resolved
Chase
Just now, Chase said:
Yes, I'll be recording it tomorrow morning (as it is still currently warm from driving).
Nah it doesn't sound like a whine, it's definitely more of a drony type noise. My main confusion is why it would disappear when blipping the accelerator? and why it only happens when cold.
I understand your confusion, I have only seen worn/loose belts do that before. They slip/squeal until you give it a rev then they grip. However that is nothing like the noise you are describing. Could it be some sort of harmonic frequency issue with something that is spinning at a specific rpm (cold start rpm). Can you recreate it when warm by holding it at cold start rpm?
So to clarify, when you start it it starts with the usual high (1500ish rpm) and makes the noise, then you blip the throttle and the noise stops and it settles down to the normal 7-800rpm?
I'd put it down to a heatshield or something else rubbing at that high idle. I know mine shakes enough more that one of the intercooler pipes would rattle but never at normal idle speed.
Or startup rod knock. Know nothing about it. Just something that came up in my searches a year or so back when having a similar dilema.
Hmm. Guess hearing it is the only way to track it further. Might find it needs a very particular rpm to rattle. Or if its on the exhaust it heats up enough to tighten up.
Try get it to repeat from cold if you blip the throttle then try match the high idle revs straight away. Could be something like a pulley bearing too, may need a jolt to get running right.
