HELP!!! will this clutch Fit my STI WRX
Thats very very very very very cheap.
Just the clutch plate alone is about $150 from Subaru i think. Thats the cheapest option, if everything else is in good condition you can just replace that.
Wow that is really cheap! I just spent ~500 at Winger for my STi clutch last month hehe....
One thing to check is the diameter of the clutch, there are two sizes of flywheels 225mm and 230mm (Pretty sure the 225 is for V2 and below), since your's is a V3 it should be 230mm so you'll need a 230mm clutch disc. Though in theory you can run the 225 but why would you when you can get more bite on your flywheel with a 230 :P
So just make sure that clutch on TM is the 230mm but apart from that don't see anything wrong, in fact it looks awfully similar to the clutch I bought at Winger lol.
