my vortex pics!
subaru-mania
 subaru-mania said:
2.jpg?t=12518813323.jpg?t=1251881579
hears what i have and whats that black tube thing in pic 1?? could i maby take that off and put a bov there?
I see a accurvator for a waiste gate.
Are you meaning the tube that sicks out side ways? if so, no you cant because thats not on the side that supplys the compressed air to the turbo.
maybe you could fit a something to the inlet manifold? then fit a bov to that etc?
 subaru-mania said:
was thinking about taking that plastic peace coming off manifold to turbo off and putting a peace of stainless steel tubing there with a bov adapter welded on to it? will this work?
That would be your "best" option.
sweet looks mint. just a question do u think its worth while doing this mod or should i just go with a fount mount?? or are they fine with out an inter cooler? as the turbo is kinda small if i was doing the inter cooler wouldn't it be better to put vf8 turbo off a Subaru legacy gt wagon on wld that work on the vortex motor safely? the one it has is a bit small for my liking.
Well the vortex isnt fitted with on so should be fine...
But saying that a cooler charge would be better. and the waic off the legacy would be more than enought.
I think a front mount would be laggy as hell... as well as bigger turbo...
Saying that my old turbo RxII had some hibrid turbo made... had a exhaust housing off the ea82T and what was supost to be a legacy air compressor housing.
what I could say was that if you wanted to replace the spark plugs you had to bunbolt the stupid thing. it was right up against the block.
If you were wanting more power drop a ej20 in :P it be a ashame to ruin a late model vortex since they are pretty rear :-\
Guest lan_killa
From memory my old Leone had a rather noisey thrust bearing, maybe this is what your hearing?
See:
around the 25 second mark on that vid and a few more times through it, @ the 5 minute mark theres a loud one
  • 3 months later...
 DRFVDR']
[quote name='G-unit said:
theres a water unit on TM with the cut already done 2 make it fit like the blue intercooler
yes that was the one I did, but never finished following the pics as my plan
u still got it :) maybe interested :)
I have a inter cooler of a legacy if ur interested? it just needs to be cut.
 Old Skool Subbie']
[quote name='DRFVDR said:
so why the cut out
wot does it need to fit around( althought i will find out tomorrow )
If I remember right its the window wiper motor is right in the way. Thats only the case if it has the spider manifold ( I Think? )
aahhhhhh yes cause of the single wiper blade
