05 Legacy rear Brembo rotor handbrake drum size/replacement
chulozumo
5 hours ago, chulozumo said:
Need to replace the brakes on my 05 legacy, it has black brembos, assuming it’s a ‘tbsti’
what’s the rear rotor handbrake drum size? Apparently in classic Subaru fashion these are different than normal brembo stuff
TIA
190mm like the STI’s on the tbSTI setups, it would be worth confirming beforehand if you can’t confirm it’s a legit tbSTI and not a retrofit.
 You need rotors that fit a V7 STI if it is for sure complete tbSTI setup
