Rear Strut Brace - Wagon into Sedan
i got mine from a guy that had it on a sedan.. fits dandy as in my wagon eh..
They run on the same chassis so as far i understand they are identical.. as is the e underbody brace.. Mine came off a type R and fits directly onto my wagon.
Only thing with yours to be careful of is the V2 -> V4 changes if any - cant comment on that sorry
 nt_a_foz said:
I thought thatd be the case.
Id assume if suspension from 1-6 fits then this will
The chassis is the same from start to then so should be sweet.
Knew the k brace will fit but cheers..
Least can test fit before buy/steal so thats alright
you should love the feel those parts give - made LOADs of diff in mine, certainly the K brace gives a big change in turn in
 driftrex']
[quote name='nt_a_foz said:
possibly man..
What you after ??
any aftermarket bits, nothing in particular really, lol. i would of been keen on that rear brace but thats yours.
i might have another rear strut brace lined up which wont cost me anyhting so if not you could prob have it...
I cant remember whats onit but i think we dismantling this weekend and will post up parts on CS.
hey nt_a_foz im thinking about doing these but wasn't to sure if it would make much of a noticeable difference on the type r with it already being so stiff with the seam welded chassis. Could you post up your opinion once you've taken it for a drive through the windy's would much appreciate it. Cheers
You can feel the difference in an r putting a rear brace on.
But i don't think it made the car any faster thru the corners
IMO better things to do first
ARB / swaybars will do more than any strut brace will ever do. Front and rear both will make you faster.
Bet bang for buck.
Better pads / fluid
I like the brake brace - its worth it i reckon for its feel alone.
Camber adjustment front / rear
Bet bang for buck.
Better pads / fluid
Swaybars might be the next hting i need to look into.
Getting some pads before the next track day.
And camber adjustment via adjustables so thats fine.
Cheers for that Qwerty handy info
 stance said:
^ Strut braces don't affect body roll
no but they help to reduce the body flexing which is obviously going to help round corners at speed, i think thats what hes getting at. strut braces are good at doing what they are designed to do, swaybars do a totally different job.
