pinning cylinder walls
Putting pins in between the cylinder walls and the rest of the block on an open deck motor to make it kinda semi-closed deck. You can also machine a plate to close the deck if you're getting really serious. Or just use a semi-closed or closed deck block in the first place.
some engines were never made closed deck.
how are the pins fixed?
Who is TRP?
Need a reliable 500 hp @ 5000 rpm for hour long runs.
Talked to an engine builder (builds 1000 hp drag engines from ej blocks.) and he was surprised I had to do any thing with that low hp.
 DRFVDR said:
I would say that is exactly the engine he going to do it to as well
EG33 for his boat
Not that obvious am I?
mostly i have read it a few times and couldn't picture it.
