Oil Temp Gauge
nt_a_foz
 MAD said:
anyone know a good place to get remote T adapters from for oil pressure, going to run my gauge from the oem oil pressure port and T join the both senders.. dont want to use a remote oil filter thingy.. looking something like this.
Best way is to make up a hose using 1/8NPT to -4AN adapters and -4 braided hose to get the length you need. Then just use a female 1/8" NPT tee.
Can get the fittings required from a motorsports supply place (if you want to use Earl's or similar branded fittings), or from STAParts.co.nz or I think you can get fittings from most Hydraulic supplies places.
Is it Boostcut? on here that was selling this type of thing custom made for much cheaper than what you can normally get it for.
Also a good place for cheap brass fittings is Plumbing World or Mico's etc. 1/8th NPT is normal for gas fittings.
 boostcut said:
haha na it wont bro, id have to sell him a new one lol, yeah it will be fine. depends what he wants to do....
sweet, I only want run an electronic oil pressure gauge, thought the best way would be to use some thing like the picture above to tap the oem oil pressure port and run both oem sender and the after market sender off the remote T piece..
if you can make up a unit like this, pm a cost .. cheers
On the otherside, just curious, is not possible to connect the oil pressure gauge to the oem oil pressure sender and get the oil pressure reading from that?
